abs/brake light on dash
Old 01-24-2011 | 10:35 AM
alcors11's Avatar
Does this recall cover 2005 Silverado? My ABS and Brake dash light came on and I "field tested" the brakes thay worked fine. Its below zero and when I checked the brake fluid after I came home the light went off? Sounds like a senor is messed up.
  #12
Old 01-24-2011 | 05:14 PM
rjccml's Avatar
I have a 2000 silverado 1500 with the flashing light syndrome also. I replaced all the brake lines several weeks ago due to rust. Yesterday the ABS light, Brake light and now the 4WD lights are coming on and going off. I DONT HAVE 4WD. The brake fluid is fine. ABS seems to work fine. and I dont find a front drive train. There is no rhyme or reason to the flashing. Trust me I recorded it and watched it back on my phone. Nothing when stopped. Just when moving. The next thing I will check is the wheel sensors. Any ideas or solutions? I hope I can fix anything.
  #13
Old 01-27-2011 | 09:33 AM
GM Customer Service's Avatar
alcors11,
If you would like to email me with your VIN I would be happy to look into recall information for you.
Christina
GM Customer Service
  #14
Old 01-27-2011 | 11:13 AM
cheaptric's Avatar
My son's truck has the ABS/Brake light on too. We checked the parking brake by unplugging it and the light started blinking. We then checked the brake fluid sensor by unplugging it and the light went off. We believe it's a bad sensor. Does anyone else's truck have this same issue?
  #15
Old 01-28-2011 | 02:20 PM
rjccml's Avatar
Originally Posted by GM Customer Service
alcors11,
Christina
GM Customer Service
My brother suggests that one of the front wheel hub monitor being bad. The computer doesnt see the wheel turning so it turn off the ABS system. That triggers the light. Since there is a series of lights flashing at different times I can imagine the computer trying to reset and monitor the wheels
  #16
Old 01-30-2011 | 08:36 AM
alcors11's Avatar
can i post the vin via e-mail?
  #17
Old 11-17-2011 | 09:15 PM
tukn20s's Avatar
Originally Posted by ChevyGirl
alright, so i have a 2000 chevy 1500. randomly the abs & parking break lights will pop on while im driving. what could cause this or what could i do to fix it myself without going to a shop?
im having the same problem with my 2000 silverado. anyone have any suggestions? i will be giving the dealer a call regarding any recalls..
  #18
Old 02-13-2013 | 11:36 PM
audioguy07's Avatar
Default EBCM Bad solder joints
it could also be the solder joints inside the EBCM Relay under the drivers side door in the inside of the frame rail. The solder joints were pooly done from factor and have a tendency to loose connection momentarily which will throw the codes but when you turn the truck off and on again it will reset since the connection is stable again.
Resolder the joints in the relay. Search you tube for Silverado Relay Fix
05chevytruckguy
02-15-2012 09:58 PM
GMCSierraFan
04-25-2011 04:38 PM
skoot61
01-31-2009 10:05 PM
munter
10-13-2008 05:54 AM
dharsen
01-25-2008 12:54 PM
Quick Reply: abs/brake light on dash
