AC and vent issues
AC and vent issues
Hi, i have an 05 Silverado Z71 and im having some issues with the ac and air vents im hoping someone could help me with. Here's whats happening...i can be riding down the road with the outside air coming in and all of sudden it will start blowing hot air as if the heater is on. The truck has dual climate control and both are all the way down in the blue when this happens. Also i can have on the ac and it will be so cold it will freeze you then suddenly it will also start blowing hot air. Has anyone experienced this before and if so what is the problem? Any help would be greatly appreciated. Thank You! Mike
Could be a couple things. Try look into replacing the A/C Cycle switch. Its about $13 and real easy. If that dont help then it might be the blend door behind the glove compartment. But I think its your switch. Just ask your parts store about the info.
I have an 04' gmc sierra and I have similar problems. My A/C at first didnt work on position number 1 but would work fine on 2-5 unless I was setting in a parking lot. While setting at idle, the A/C would blow hot air. Now it only works on position 5 so I ordered a new dual climate control panel. Does anyone have any suggestions?
as for the hot air on idle, thats a separate issue you'll have to get diagnosed
