air box mod...
Old 07-06-2007 | 12:03 AM
72charger's Avatar
Default air box mod...
I cut a slit open in my airbox like MrLM7 suggested and I have to say I am amazed. It's suprising what you can do to cars now a days to make them better without even spending any money!
Old 07-06-2007 | 01:00 AM
MrLM7's Avatar
Default RE: air box mod...
Sure beats paying out the nose for an intake....Huh? It also looks stock, so you can go with the sleeper look....
Just wait until you do the other mods... The throttle body bypass is killer...
Old 07-06-2007 | 05:09 PM
72charger's Avatar
DANG! My gas mileage has gone up quite a bit. Atleast 2 mpg as crazy as that sounds.
Old 07-07-2007 | 12:01 AM
78chev2bnice's Avatar
Member
This is kind of dumb but what do you mean you cut a slit in the box? Did u just cut a hole in the top or the front? Also what is the "throttle body bypass?"
Old 07-07-2007 | 12:40 AM
72charger's Avatar
If you look at the front of the airbox(the side facing the headlight) there is a flat/smooth part just below where the air filter sits. I took a hack saw and just cut a slit about 1inch wide all the way across the side (BELOW THE AIR FILTER AS MUCH AS POSSIBLE). This is a great free mod that I highly recommend and only took me about 15 minutes... though mine was a little bit of a quick jerry rig deal.
Old 07-07-2007 | 12:42 AM
72charger's Avatar
As for the throttle body bypass I think this is where you remove the coolant lines going to and from the throttle body which aid in cold starts I think. Haven't done this. Need to look into it though.
Old 07-07-2007 | 12:52 AM
Member
I think I will cut the air box on my truck tomorrow. I wonder if the bypass will make it harder to start here in Alberta. It gets pretty friggin cold some days and I don't need it not starting for me. Ya I found the "ultimate freeby list on page 8 or 9"
Old 07-07-2007 | 01:01 AM
MrLM7's Avatar
They work VERY well...
Old 07-07-2007 | 01:31 AM
MrLM7's Avatar
Here is the link... Can somebody make this a sticky?
https://www.truckforums.com/m_17037/tm.htm
Old 07-07-2007 | 11:25 AM
smoke20's Avatar
The throttle body bypass keeps you from heating the air coming into the intake. As far as being in Alberta, you may have some issues when the temp drops to single digits and lower. It is easy to undo for the winter though if needed.
Quick Reply: air box mod...
