Air pressure light
Old 12-24-2011 | 11:08 AM
allison08's Avatar
Default Air pressure light
My 08 one ton has a "check left front tire pressure light " The issue is, the tire preesure is the same on all four tires.......Help
Old 12-24-2011 | 02:38 PM
NullHead's Avatar
Check your spare.
Old 12-24-2011 | 09:33 PM
SlimJim's Avatar
I don't think the spare is monitored. It sounds like you have a bad sending unit in the rim. I don't know what model you have but mine gives the actual pressure in each tire via the DIC. With it, it's pretty easy to see what's going on.
Old 12-24-2011 | 09:53 PM
NullHead's Avatar
I worked on a 2008ish Hummer H3 a few weeks ago that had a monitor in the spare. I'd check the pressure anyways. Can't hurt, if the spare is fine, then SlimJim is right, you've got a bad sensor.
nw911
06-09-2014 04:20 AM
rbs137
08-24-2011 12:40 AM
ElectroJoe
08-22-2011 04:21 PM
trigger07
06-12-2008 08:05 PM
popo
27
01-31-2008 11:15 AM
