Auto 4WD???
Old 02-10-2009 | 08:41 PM
chrisbmo2000's Avatar
Default RE: Auto 4WD???
ORIGINAL: ghlkal
ORIGINAL: restridge
Can you use the AUTO setting at highway speeds (60-70mph) like a AWD?
Yes
ORIGINAL: restridge
I mean it seemed, and perhaps I imagined it, to be putting extra load on the truck. It felt like it would sort ofgear down a little when I let off the gas. I also thought I could feel a little more vibration from the transfer case.
In Auto4WD, the front axle is engaged, but power is sent to the rear wheels normally. When a loss of traction is sensed, power is sent to all four wheels.
NO........I bet it only works up to 30mph like most other auto 4wd systems
  #12
Old 02-11-2009 | 06:04 PM
ghlkal's Avatar
Member
ORIGINAL: chrisbmo2000
Haven't heard of this ...
Documentation (and experience) indicates it doesn't "switch off" at a pre-set speed.
http://www.denalitrucks.com/documents/TL_Jan03.pdf
  #13
Old 02-11-2009 | 07:43 PM
ShredSLED's Avatar
Member
ORIGINAL: ghlkal
ORIGINAL: restridge
Yes
ORIGINAL: restridge
Autotrac worksfine over 30mph. Even at highway speeds. I forgot, but I just recently read the manual (looking for fluid levels/type), but if I recall correctly it mentions something about it working fine at any speed.
Just out of my own superstition, I never gas it while the light is flashing during transition...
Not for the record or anything, but in the snow I think"Auto" is REALLYfun for drifting the truck around in the slippy. Gives you that small millisecond or whatever just to kick out the rear end loose and then before you know it you're in a 4WD drift! Good stuff!
  #14
Old 02-12-2009 | 07:25 PM
ghlkal's Avatar
Member
ORIGINAL: ShredSLED
Autotrac worksfine over 30mph.Even at highway speeds.
Agreed
ORIGINAL: ShredSLED
Not for the record or anything, but in the snow I think"Auto" is REALLYfun for drifting the truck around in the slippy. Gives you that small millisecond or whatever just to kick out the rear end loose and then before you know it you're in a 4WD drift!Good stuff!
off the record, for sure ...
05 GMC
09-13-2012 05:16 PM
max
05-16-2010 10:26 AM
bill2913
03-28-2006 02:13 PM
downtowncar
11-10-2005 06:09 PM
Quick Reply: Auto 4WD???
