axle seal
Old 03-04-2007 | 04:28 PM
78chev2bnice's Avatar
Member
Default axle seal
I was wondering how hard it is to change the passenger side front axle seal, because mine has a small leak. Its on my 02 silverado 4x4 with the 5.3L.
Old 03-04-2007 | 07:33 PM
Argon's Avatar
Default RE: axle seal
Pretty tuff..
getting the axl;e out will require sway-bar link removal,and a special sized socket for the axle nut.
Then you must remove that whole alluminum tube housing with the shaft in it,and tear it down on the bench to get the 2-foot shaft out.Then replace the seal.
In other words...look where your leak is...the rf axle bolts to a flange...that flange has a 2-foot shaft in a housing...that whole housing must be removed.
Komrade
03-23-2013 07:42 PM
Brew8
12-30-2011 05:47 PM
timothy
10-28-2009 04:23 PM
bfazz
10
11-07-2007 05:25 AM
nhbp06
07-02-2007 05:51 PM
Quick Reply: axle seal
