Back brakes locked up
Well to begin with i knew my brakes were low when I took the drive to SC to FL.. Well when I got to Fl it was metal to metal on the back driver side so I replace both sides of the back brakes and rotors. Well after doing all this and bleeding the brakes i felt like the truck was dragging in the rear and kept smelling brakes.So I figured one of the calipers were locked up so I changed both sides and bled them of course. Now the back brakes are still locked up and doesn't want to even move from the drive way. The only other things I can think is the master cylinder or a hose is backed up... Any feed back with be much appreciated. Thanks guys
SHAME SHAME Shame on you.. Taking your truck on a road trip knowing your brake weren't up to the trip. Then driving your poor truck with metal on metal.
I sentence thee to 2 weeks of brake problems and expensive repairs
WELCOME to Truck Forums.
Your locking back brakes could be a number of problems.
-but i think your rear calipers either need to be rebuilt or replaced
Once you jack it up and get the wheels off, you will be better able to see what is hanging up. If it looks like a caliper piston is not backing off, you can crack the bleeder and see if that helps. If it does, since you have already replaced the calipers, it could be a bad hose. You also need to make sure the pads are able to move freely on the guides and make sure the emergency brake is adjusted OK.
How does the fluid in the master cylinder look? Especially since things have probably been pretty hot from the metal-to-metal contact, it might be a good idea to flush your brake fluid.
Gerald
Gerald
So assuming you have rear disk brakes, the road trip with metal on metal probably melted the piston cup seal inside your caliper.
I say jack up the rear, pull the rear wheels off a just look at the rear brakes. Look for a gap between the rotor and the pads. Pump the brakes, and then go look again. There should be a gap. If there isn't, I think that you have an issue with the piston cup seal and you need to replace your rotor. Don't bother rebuilding them. Rotors are cheap, and guaranteed.
Bleed the system when you're done.
Thanks for the info but iv already replace rotors and clalipers(both sides) so i dont think thats the problem is. How can you check if a hose is bad or not cause thats about the only thing I can think that could go wrong that hasnt been replaced.
Well if everything is new... Do like glterpening (gerald) said. Jack up your truck and take the wheels off. If the brakes are dragging now. Release the breeder valve to see if the brakes back off.. That is a sign you have a flex line problem on that wheel.
zeater04
01-30-2012 11:36 PM
