battery cable connections...
Old 06-17-2007 | 09:46 AM
neR10's Avatar
Default battery cable connections...
Hello all. I'm a little confused. I'm finishing up with a 350 install in my 1987 R10 P/U. I'm not sure where all of the connections go for thebattery cables. You have the ends which obviously connects to the battery, and then you have three other connections. There is a long thick cable, a medium shorter cable, and a thinner cable. I am guessing that the long thick one attaches to the starter, I saw a picture of the medium cable attacked to the alternator bracket for a ground, and it looks like the smaller cable attaches to the back of the alternator. Does this sound right?I don't want to end up frying something...
Old 06-17-2007 | 10:14 AM
stopspazinout's Avatar
Default RE: battery cable connections...
no no no. there should be a cable that is bigger with 2 wires that goes to the starter. then the other is a ground. and just attaches somewhere to the engine.
Old 06-17-2007 | 04:51 PM
neR10's Avatar
Okaywait, I looked at it wrong. Both the positive and negative cables have two wires each; a large one and a small one. Does the large positve connect to the starter, the small positive connect to the alternator, and the two negatives connect tothe engine and body? (one negitive is still connected to the inner fender)
Old 06-17-2007 | 07:05 PM
Argon's Avatar
the ground cable..the big one to the engine block...not the intake or exh manifold...look down lowww,by the harmonic balancer...the small eye grounds to the fender well
Old 06-17-2007 | 07:34 PM
and the big the pos goes to one terminal on the starter and the smaller one goes to the starter solenoid.
Old 06-19-2007 | 09:57 AM
MrLM7's Avatar
ORIGINAL: neR10
HEHEHE
Old 06-19-2007 | 09:46 PM
yes... he said it.
MightyMike
08-06-2012 01:52 AM
mlongue1
11-14-2007 09:10 PM
street silver 1
10
09-10-2007 10:19 AM
unit731
06-07-2007 10:22 AM
vintage4x4
08-31-2006 04:34 AM
Quick Reply: battery cable connections...
