Battery Light
Old 07-09-2005 | 02:22 PM
mfarberg's Avatar
Default Battery Light
I just replaced the alternator and battery on my 99 silverado. Battery is showing
about 13 volts and when running showing about 14.8 volts. Looks good but the
battery light is on, on the message center and wont shut off even though everything
is running fine.
Old 09-07-2005 | 10:18 PM
silovervortek's Avatar
Default RE: Battery Light
Along with the red fusable link going from the alternator to the battery there is a connector with i think 4 small wires on it that connects to alternator as well, if you missed the small connector the comp wouldent know the alt was charging.
If thats not the case disconnect the battery cable for a minute and them re connect this might put computer back in learn mode and it might pick up that the alt is charging. [mind you turn your radio alarm off before disconnecting battery].
The fusable link must be ok if it is showing the 14 volts on the battery terminals.
MightyMike
08-06-2012 01:52 AM
twotone
08-06-2011 03:12 PM
atenney
12-17-2008 11:45 AM
nashduck
11-14-2008 08:05 AM
ChevySilverado03
11-05-2007 01:46 PM
Quick Reply: Battery Light
