beater truck need help
it is a 75 cheyyene it has an older goodwrench 350 in it the carb is a carter quadrajet with abunch of diconnected vacuum hoses.
I pulled the dipstick and it was dark but not that bad .
the atf fluid was pink?
RE: beater truck need help
What is your question??
The ATF fluid should be red, but pink is about right.
The oil is probably not a bad thing unless you found that when you start it up it turns milky.
The vaccuum hoses can be fixed really easy with a chiltons manual.
Any thing else??
Any thing else??
westtndad
8
01-28-2015 03:06 PM
chevydream
11-02-2005 04:05 AM
