Bed bolt size on 1994 Sierra?
Old 07-01-2011 | 09:42 PM
JohnBinTN's Avatar
Unhappy Bed bolt size on 1994 Sierra?
Just got a 1994 Sierra, and noticed alot of rattling when driving. Just went out and discovered the bed bolts (I doubt all of them, but some - it's getting dark out, etc.) are missing.
Anyone know what size they are? I've gathered there are 8 somewhere under there - I found the two at the very back (where they should be, anyways).
I'd prefer to just go buy them before I go hunting around for one that's there so I can locate/replace at the same time.
Appreciate any help anyone can offer! Thanks!
John in TN
Old 07-01-2011 | 10:09 PM
To be on the safe side I would remove one and go match it up.
Old 07-02-2011 | 12:51 AM
JohnBinTN's Avatar
Red face
Thanks, Shamrock.
I found on Google that a 1988 takes M12x1.75x35, so since were going into town early AM, I'll pick up a few of those and cross my fingers. If they don't fit, I'll make them fit.
John
P.S. Any ideas for a rigged spare tire lowering tool? I'm using a screwdriver and a vice grips, but it takes a long time / lotsa work.
P.P.S This is my first truck.
Old 07-02-2011 | 08:25 AM
Hit the junk yards and get the factory tools if the mechanism is still working properly. The tool you use to remove your lugs should have a point on the other end that when used with the ratcheting tool makes removal fairly easy. It goes in through the hole in the bumper.
Old 07-02-2011 | 07:39 PM
JohnBinTN's Avatar
I was able to re-use the old bolts with addition of galvanized washers. Lots of bolts missing under there - surprised it's still in one piece.
As for the spare tire lowering tool, I made a functioning one by using a 1/2" wood spade bit in a 1/4" socket with extension. It works, and it's not like I'm changing tires everyday, anyways.
Old 07-02-2011 | 09:10 PM
Glad you got what you needed - thanks for letting us know!
BirdDooHead
12
06-19-2014 07:30 PM
imariver
10-26-2012 12:14 AM
supra1rd
Vehicles for Sale
09-23-2011 07:19 PM
chucksrt
12-22-2010 03:09 PM
archerynut36
08-24-2007 01:01 PM
