Best Oil for MPG
Old 12-15-2010 | 04:41 PM
lmatney03's Avatar
Member
Default Best Oil for MPG
I'm about to change the oil in my silverado. What's the best oil out there for getting the most mpgs? Thanks.
Old 12-15-2010 | 06:33 PM
jimmie.cutler's Avatar
what weight have you been using and what type of climate do you live in
Old 12-15-2010 | 06:48 PM
lmatney03's Avatar
Member
It'll average in the 30's where I live for the next 3,000 miles at least.
As for the weight, I have no clue. Don't know much about oil. That's why I'm asking.
Old 12-15-2010 | 09:44 PM
as long as your not using a heavy weight oil like 20w-50 you should be fine on mpgs. The 4.3 probly calls for 5w-30 or 10w-30. check your owners manual and it will guide you in the right direction. However the difference in mpgs on those oils will be so small that it really wont be noticeable. If it were mine i would run 10w-30
Old 12-16-2010 | 09:49 AM
wellmax's Avatar
Member
if your motor does not have excess miles, 75K or more and has received proper regular oil changes, i would use 10w30 full synthetic oil of a major brand like valvoline, etc:
hands down full synthetic oil has better lube properties, but in older high mileage engines it can cause oil leaks as full synthetic oil has smaller molecules than dino oil.
Old 12-16-2010 | 11:44 AM
lmatney03's Avatar
Member
Well it's an 06 with about 85,000 miles on it. Has been wrecked if that accounts for anything.
Old 12-16-2010 | 03:54 PM
ModzMan56's Avatar
as long as your not using a heavy weight oil like 20w-50 you should be fine on mpgs. The 4.3 hid headlight kits probly calls for 5w-30 or 10w-30. check your owners manual and it will guide you in the right direction. However the difference in mpgs on those oils will be so small that it really wont be noticeable. If it were mine i would run 10w-30
Yea 10W 30 is always a good choice.
Old 12-16-2010 | 04:45 PM
chevychase's Avatar
It is colder . Chevy trucks like 5w-30 .
I tried 10w-30 no cigar, started getting that lifter peck.
Old 12-17-2010 | 03:44 PM
Boss Hoss 540's Avatar
Used several in the past but AMSOIL Signature Series 0W-30 Synthetic Motor Oil is what I run in everything. Expensive but run it 15k total-----7500 new filter and add a quart.
There are only 3 oils availaible in the us that are true synthetic in origin and Amsoil is one. Lot of oils are synthetic by the USG definition but are only a % synthetic.
Old 12-17-2010 | 09:27 PM
For those miles I would put 10w-30 in it. It really doesn't matter what kind or brand just aslong as its not that really cheap stuff or the stuff that has paraffin wax in it like pennzoil or quaker state.
Harland
09-21-2012 09:20 AM
lmatney03
04-08-2011 11:41 PM
Worf
02-21-2011 03:11 AM
Vulcangw
12-26-2007 07:03 PM
