Big mechanical problem
Old 05-31-2010 | 10:20 AM
80skeys's Avatar
Member
Default Big mechanical problem
1991 k1500 350 automatic 4x4.
Was driving back from the lake yesterday towing the boat. I frequently switch between (D) and D as I'm driving depending on the hills. Was driving fine along a flat stretch, suddenly heard a metallic bang and the truck started vibrating a lot at low rpms.
Got out, looked underneath, didn't see anything out of place. Looked under the hood, didn't notice anything.
Got back in and drove home. Lots of vibration at low rpms. Loses power going up hills. Drives okay on flat stretches and at high rpms. When in Park or Neutral the engine sounds fine when it's revved high. But when in gear there's a lot of low-end vibration.
I'm thinking transmission or transfer case blew a gear. Or maybe the motor threw a rod. What do you guys think?
Old 05-31-2010 | 10:33 AM
chrisbmo2000's Avatar
sounds like a tranny or t case problem....I would look at the t case first....drain the fluid and see what you see......
Old 05-31-2010 | 10:39 AM
80skeys's Avatar
Member
Good idea, I'll do that today.
I looked at the tranny fluid. It looks fine, but does not smell normal.
Old 05-31-2010 | 07:25 PM
SlimJim's Avatar
If you had thrown a rod, you would not be able to sit still and rev the engine. I think it's in the transmission. Do you have all your gears?
Old 05-31-2010 | 08:49 PM
acnas's Avatar
How are the u-joints?
Old 05-31-2010 | 08:56 PM
80skeys's Avatar
Member
Yes it has all the gears. But it vibrates a lot at low rpms in each gear and loses power.
I plan on checking the u-joints and the transfer case tomorrow.
David S
03-06-2013 08:44 PM
superstu240
Silverado/Sierra FAQs
07-24-2011 04:11 PM
Mr_Shamrock
9
07-06-2009 02:40 PM
pipestone
01-09-2008 01:57 PM
bigtruckguy256
02-19-2007 04:25 PM
Quick Reply: Big mechanical problem
