Blinker blowing fuses
Old 02-10-2011 | 05:49 PM
Default Blinker blowing fuses
So last week after plowing for 12 hours on wednesday, My turn signals quit working as well as the parking lamps. The lever would lock into position but nothing would happen. I found it was a blown fuse and replaced it... didn't think anything of it.
So today I haven't plowed at all and I parked the truck for an hour. Came back outside and the turn signal doesn't work. I just did a quick check, but it seems that all fuses are good... any ideas?
I am aware that I have a faulty ignition switch... could it cause the problem?
Old 02-10-2011 | 08:56 PM
RUFFNECK4LYFE's Avatar
Not sure, but Im sure once you replace it, we'll find out then, although Im guessing it is.
Old 02-10-2011 | 09:24 PM
I'm too cheap to replace the ignition switch until it warms up and I can do it myself...
Anyways, I did some more searching, and while last time the turn signal fuse was blown, this time it was my hazard/door dinger fuse that blew this time.
I'm just curious whether or not it would be connected to that ignition switch problem??? I've postponed the switch replacement by tying the acc and on power lines together so I'm drawing power from a different source. I don't want to replace the switch and find I've got a bigger more expensive electrical problem on my hands
cobrajocky
10-25-2012 01:40 PM
Kayanne
12-06-2010 02:21 PM
rmurphy5
06-16-2010 07:04 AM
cnd
08-26-2006 04:22 PM
guitar_icon
03-22-2006 02:39 PM
