Brake Rotor Help.....
Old 05-01-2010 | 08:06 AM
jstutz101's Avatar
Default Brake Rotor Help.....
I am in the process of trying to replace my front speed sensor and cant get the rotor off. I noticed there are a couple of threaded holes on the rotor. Are those there to helo remove the rotor? If so does anyone know what size they are?
Thanks!!!
2007 1500 Classic
Old 05-01-2010 | 09:46 AM
Anaudiophile's Avatar
The threaded bolts holes are for installing bolts to "help" remove the rotor. Usually a few good smacks with a decent sized ballpeen hammer between the studs gets them off. If you have to use the bolts to remove the rotor, do it a bit at a time. I've seen rotors split/crack around those holes. Being an '07 I wouldn't think it would be rusted on that badly!?
Sorry, I'm not sure what the size bolts will fit (8x1.25 or something?)
Old 05-01-2010 | 11:06 AM
jstutz101's Avatar
I'll try hitting it again. I probably need to but more muscle into it. I was afraid I was missing someting obvious that was holding it on so I didn't want to hit it to hard. Thanks for the help!!
Old 05-01-2010 | 04:04 PM
xpeder's Avatar
there is torx screw t30 holding it to the wheel hub
Old 05-01-2010 | 07:16 PM
jstutz101's Avatar
Wheres that at? Is it on the front of the rotor??
Old 05-01-2010 | 08:15 PM
acnas's Avatar
I think if it is the new body style it has the torx bolt?
Old 05-01-2010 | 08:28 PM
jstutz101's Avatar
Post
That makes me feel better, I looked for some kind of fastener holding that rotor on there. I got a bigger hammer, going to try that tommorow. Being that it will be Sunday and most parts stores will be closed I will surely screw something up..
Old 05-02-2010 | 10:45 AM
jstutz101's Avatar
Got it off!!! Just needed a bigger hammer. It also helped to turn the wheel to give me more room to swing.
Thanks for all the replies!
bpa1216
03-21-2010 05:40 PM
Clubmike2910
02-28-2010 06:35 PM
bfg112
07-08-2009 07:05 PM
lossinthought
09-24-2006 06:18 PM
daggettdaddy
09-24-2006 01:13 PM
Quick Reply: Brake Rotor Help.....
