Broken Antenna
Old 02-07-2008 | 08:14 AM
Mudder69's Avatar
Default Broken Antenna
Some dumb A$$ broke off my antenna by over tightening it. So now the metal screw is sheared off. has anyone replaced the metal braket holding their antenna in place?
Old 02-07-2008 | 09:42 AM
rxsteven's Avatar
Default RE: Broken Antenna
You should just do the anntena mod!!
Figured this out when I was bored. Pop your hood and pop off the little blackplastic cowlpiece that goes around your antenna. There are two clips in the rear, and one in the front. Next, remove the three bolts that secure your antenna to the base. Remove your antenna from the base and unscrew your antenna from the connection. Finesse your connection around the hoodhinge and re tighten your antenna and lay it down along the top of the fender. 99-02's can actually put the antenna through the rubber snubber and hide it under the hood seal... Just snap the black plastic piece back on and bingo. I've heard you can order a cowl piece off ofan Escalade that does not havean antenna hole initfor like $10...
Thanks to Mrlm7
Old 02-07-2008 | 02:32 PM
Mudder69's Avatar
i thought of that but the metal piece that the antenna screws into is broken so i don't have any where to attache the antenna to. do you know if the wire that plugs into the metal bracket can be separated? If so, I'll be able to do this mode, if not, then I'm still in the same predicament.
BeckyAZ
07-25-2009 12:17 PM
Hawg1
03-04-2008 11:23 AM
MrLM7
25
02-16-2008 08:21 AM
mbrady8
01-21-2008 09:01 AM
04 sierra xcab
10-13-2007 01:35 PM
