a/c floor leak
Old 06-17-2007 | 06:01 PM
gsteiner's Avatar
Default a/c floor leak
99 silverado and 99 tahoe leak water on floor passenger sidewhen using a/c any help? truck leaks some when in rain. no rust on either. thanks....
Old 06-17-2007 | 07:02 PM
Argon's Avatar
Default RE: a/c floor leak
first,you have to establish it IS a/c water...if it is..
look under the hood and make sure your "boot" is there..its a rubber,90 degree boot on the drain..it prevents wind rush from blowing the a/c water back in the case.
you can slip the boot off,and blow air in the drain to try to unclog it...
if its not clogged,and the boot is there,AND its a/c water....about all ya can do is remove the hvac case and reseal it
f350 help
12-20-2007 03:49 PM
gsteiner
06-05-2007 03:11 PM
Z71Nutty
11-10-2006 05:00 AM
badboysinc.
07-11-2005 02:43 PM
HEMI 7
05-27-2005 03:26 PM
Quick Reply: a/c floor leak
