caliper problems
Might try spraying a can full of penetrating oil on the bolts and letting them sit - follow directions on the can. After they soak a bit, you could try giving the head of the bolt a good whack with a mallet. Don't use a hammer because it might damage the head. Maybe put a block of wood over the head of the bolt and then hit it. Might break it loose.
Sounds like ruffneck's suggestion might be easier, tho. I haven't tried it. Good luck!!!
