Carbon Cleaning
Carbon Cleaning
My 02 6 litre was ticking pretty bad all the time, and I've read about carbon on top of the pistons (ARGON's threads of course)causing it to tick like a lifter, Well i got a Dawn dish soap bottle and cleaned it very well, then filled it with hot water and while holding the RPM's at about 3500 sprayed it into the TB (no i did not spay the MAF) and a whole lot of nasty colored smoke and steam came from the tailpipe. After i emptied the 25oz bottle I held the throttle for a few seconds to clear the manifold. Hooked the MAF back to the TB, and BAM no ticking. I know there are a few guys who will bash the idea of dumping water into the intake, but it worked. If you try it, make sure you dont squirt to much water in there, you could hydrolock that bitch.
RE: Carbon Cleaning
I was just so tired of that stupid ticking noise, i was willing to try anything.As long as you dont use a garden hose, i think you will be fine. And yea it really worked. If you do a search for cabon you will see that Argon tells everyone that it's carbon causing the ticking noise, but he will tell you to use GM top engine cleaner, which im sure is the right way, i just dont like to wait 24 hours for that stuff to work.
