carburated heads question......
Old 05-06-2008 | 12:41 AM
jagman454's Avatar
Default carburated heads question......
Ok, heres the deal, I have a 350 block out of a 90's truck, i'm putting it into a 84 scottsdale it has a 305, i'm converting the fuel pumps and heads/intake with a new carb, ok I want to pick up a used pair of vortec heads to put on it, but I'm not sure if they make carburated vortec heads, does anyone know any cars/trucks I can pull them from along with the intake to bolt it up to the 350?
P.S. does anyone know a good/cheap way to get some extra HP out of some heads, I have the original scottsdale heads, but I want to replace them with some vortec heads..hence the quetion....
thanks alot!
-Mitchell
Old 05-06-2008 | 06:06 AM
Argon's Avatar
Default RE: carburated heads question......
vortec heads are completely different...your carbed intake will not bolt to it..however,i've heard of custom intakes that bolt to vortecs and hold a carb
Old 05-06-2008 | 08:48 AM
jcbst12's Avatar
Edlebrock makes an intake like that and I believe summit makes a cheaper one too. Yes, they will bolt to the vortec heads and a carb. My suggestion would be to get a quadrajet (sp?) carb and slap that puppy on there. If you get the carb jetted right it will give you plenty of power and as long as you keep the secondaries from opening up all the time your gas mileage won't suffer too much (AKA lay off the pedal!)
Old 05-06-2008 | 07:03 PM
03missouridirt's Avatar
Are the 305 heads in useable shape? What casting# are they?
Old 05-11-2008 | 10:00 AM
jagman454's Avatar
The 305's heads are in usable shape.. dont know the casting # tho I might be able to find it out if you really needed it, (oil all over the place), where is the # located?
Old 05-11-2008 | 10:07 AM
jagman454's Avatar
Are you guys talking about this intake? http://store.summitracing.com/partde...p;autoview=sku
Old 05-11-2008 | 02:27 PM
Located under the valve/tappet covers.
And , Yes. That is an intake like you would need...
SovereignDragon
06-20-2009 04:37 PM
midge93
01-15-2007 04:08 AM
GEARHEADRT
13
12-29-2006 12:22 AM
Vetteguy
11-03-2006 12:23 AM
turboscrew
09-30-2006 03:56 PM
