Changing the crank in the burban :(
Well I spun 2 rod bearings in the burban when we got that last major snow (go figure) so since it has been 80 degrees for the past 2 days I am going to swap the crank. Any one got any suggestions???? Or helpful hints? I will try to post some pics also....but no promises
383 2 pc. rear main in place o a 1pc.90 chevy 4x4
1990 Chevrolet K1500 Silverado 8Cyl5.7L - Engine
2 bolt rear main block in place of a one peace rear main block in 90 k1500 w/ 5 sp. manual trans ,clutch throw , T.B.I.s
I'm Trying to engine swap a 2 pc, rear in place of a 1 pc .clutch to crank, and the stock tbi set up. int, and exh. manifolds hook ups and other related swaps ,with . Any help would be appreciated//,,stevejohnson48
This is the engine that I'm trying to salvage in the project//...Engin for sale.383 Chevy.Built right.all the good stuff.Sml. block,2pc. rear main seal.Keith Black pistons.deck plate bored & honed.Enki mega cam.(280)low base circle.Rods polised magnifluxed,resized,shot peened,& balance.Moly push rods(+.100).cam button(needle barring).moly bolts throughout(warshers on heads).Rhoads lifters. (1.52) Comp cam roller tip rockers.Heads are matched ported,smoothed runners,both intake,&exh.Valve bosses tapered .New harmonic balancer,& flex plate. Eldlebrock Proformer manifold.To much more to list. All reciepts & specs. 390 + h.p.420 tq.Has shims under stock springs.Needs stronger springs.All toleraces checked & ct.double ckeck,end play,rod to journal clarences ect. $2200.00 obo. 9.6 to 1 cr.
cubpak89
12-23-2011 01:14 AM
grinchmoney
08-31-2010 01:21 PM
crankyyank
08-08-2010 07:37 AM
