Cleaning throttle body 2006 Silverado
Old 12-30-2011 | 01:26 PM
dennisinmo's Avatar
Default Cleaning throttle body 2006 Silverado
2006 Silverado LT 4WD 5.3L 93k miles
Is it possible to open the throttle body air inlet valve while the motor is running to spray cleaner into the throttle body? Is this practice still a method to clean the throttle body? I see the throttle body is not mechanically linked to the gas pedal; it looks like it is motor driven or something. I tried to push the valve open but it would not open. I didn't want to force it open and break something.
Thanks
Old 12-31-2011 | 07:26 PM
Wiked's Avatar
its electronically controlled
turn the key to ACC (last click before you turn on engine) and put something on the gas pedal to open up the throttle body and do your cleaning,
be aware though that the cleaner will thin your oil a bit and will cause a hard to start after all that stuff goes into your intake
Old 01-01-2012 | 12:32 PM
dennisinmo's Avatar
Thanks Wiked
I'll look around for a brick to use in the process of cleaning the throttle body. How times have changed working on motors.
Old 01-01-2012 | 04:27 PM
Wiked's Avatar
tell me how it goes
lmatney03
03-11-2011 07:41 PM
DarrenPaulSmith
01-28-2011 10:00 AM
lmatney03
01-27-2011 08:41 PM
cyberal
01-03-2009 12:58 PM
bigred29067
05-24-2008 04:14 PM
