Codes po131,171,300
Old 11-29-2010 | 05:51 PM
Artfta's Avatar
Default Codes po131,171,300
I have a 2004 5.3l runs really roughat an idle mostly. 40,000 miles check eng light came on and codes po131,171,300 came up.
Checked spark plugs and all 4 on drivers side were black other side was fine.
Any ideas?
Thanks
Old 11-29-2010 | 09:10 PM
rmck490's Avatar
Here's a few links that may help a little:
http://www.obd-codes.com/p0131
http://www.obd-codes.com/p0171
http://www.obd-codes.com/p0300
Probably all three are related to one problem. Your plugs are fouled because the PCM thinks Bank 1 is too lean so it's throwing more fuel to that side. The random misfire code may be related to the plugs being fouled.
I would suspect the problem might be the O2 sensor on the driver's side between the exhaust manifold and the catalytic converter. The P0131 code indicates that sensor has a low voltage (if any) which the PCM interprets as a lean condition. Check the wiring to the O2 sensor for a broken wire or short to ground. You could replace the sensor but that's throwing parts at the problem. You may get lucky if that's the problem but you might not either. A technician can check the sensor for you. I'd start with that and clean the MAF as well.
Old 11-29-2010 | 09:12 PM
AaronDzik's Avatar
http://www.obd-codes.com/trouble_codes/ this should give you the full list of dtc's and a brief explination... this should at least get you on the right path
Old 11-30-2010 | 09:02 AM
Artfta's Avatar
Thanks guys I will check the O2 and clean the MAP today ...I will let you know.
Thanks again.
Old 11-30-2010 | 07:42 PM
Artfta's Avatar
It was the O2 sensor...Thanks again.
Old 11-30-2010 | 09:29 PM
rmck490's Avatar
I'm happy to see you got it fixed.
stormy76
08-18-2007 05:52 PM
MrLM7
04-11-2007 09:27 AM
Old Rust Bucket
08-25-2006 12:36 PM
JSMConstruction
04-04-2005 02:24 AM
JSMConstruction
05-22-2004 07:10 PM
Quick Reply: Codes po131,171,300
