Cold Air Intake preferances
#11
RE: Cold Air Intake preferances
superddd - the intakes also have larger filter surface area and a continuous pipe to the throttle body, unlike the passageway (or whatever you call it) that comes stock and has sound dampeners and goes multiple different directions for some reason. If you actually pull it out and look at it, it will make more sense, it is hard to describe what it looks like. Yes they do still pull air from the same place if you don't have the scoop, it just pulls more.
#12
well i personally think which ever one is not made of metal is great. asi have posted a while back......the numbers have been shown, the metal tubing conducts heat, and in turn causes you to have power robbed due to high intake air temps. Now should i say anything i would say AIRAID or Volant just my personal choices.
#13
Just bought the volant one and love it so far! I don't know how much it made a difference in the milage yet but there is a good amount of power difference. I really noticed it going down the highway and passing another car. I was doing 60 and barely got on it and I looked down and it was all of a sudden at 75. Has anyone gotten the scoop the volant sells for the kit? Or have you done anything to the hole that is in the bottom of it?
#20
New here but adding my .02. I got the True Flow for mine it does add some decent power. However I can personally tell you that if you are looking for something that will give you a better tone from the motor the true flow will not be the one to buy as it makes use of the stock air box.
