is it cool to lift a v6?
Old 03-23-2008 | 11:08 PM
revans7108's Avatar
Default is it cool to lift a v6?
i was wondering if you had a v6 would you lift it because im not sure if i should or not... want a 3 in body though
Old 03-24-2008 | 12:37 AM
chevy112488's Avatar
Default RE: is it cool to lift a v6?
i dont know... i've never driven one if you think it would turn over bigger tires go for it...
Old 03-24-2008 | 12:55 AM
MajorSilva's Avatar
ORIGINAL: revans7108
i was wondering if you had a v6 ENGINE BLOCK would you lift it OUT OF THE TRUCK AND REPLACE IT WITH A V8because im not sure if i should or not...
Fixed it for ya! To answer THAT question, yes, yes you should go ahead and get a V8.
Old 03-24-2008 | 01:41 AM
1997 chevy's Avatar
i say if its not v8 or bigger then its not worth having around
Old 03-24-2008 | 09:35 AM
jcbst12's Avatar
Lifts are Ok BUT.....
V6s + big tires = no ***** and bad gas mileage
Even my 91 was sluggish and bad on gas when I had bigger tires on it and it was a 5.0.
The guys at RCS (local engine builders and fabricators) tell me that v6s and low hp v8s are terrible to lift and have huge tires on.
Old 03-24-2008 | 04:55 PM
revans7108's Avatar
if i were to put a v8 would i need a new transmission or no?
Old 03-24-2008 | 06:40 PM
rxsteven's Avatar
What trans do you have now? And a body lift wont effect your engine performance but if you plan on going with bigger tires you will want to get different Gears. Here's a good thing to bookmark http://www.4lo.com/calc/geartable.htm it tells you what size gear youll need for what ever tire size you run.
Old 03-24-2008 | 07:05 PM
revans7108's Avatar
it has a 4 spd electric transmission and my gear ratio is 3.42
Old 03-24-2008 | 07:29 PM
rxsteven's Avatar
Is it a 700r4 or a 60e 65e 80e 350 turbo 400 turbo
Old 03-24-2008 | 07:44 PM
revans7108's Avatar
i really dont know the answer to that because simply i dont know what that is...im trying to learn about trucks (especially chevys)
Quick Reply: is it cool to lift a v6?
