Coolant in oil
Coolant in oil
Well after losing coolant for a while ,it finally showed in the oil filter today. The tsb I found on a search here, 06-06-01-019b does not list a NB 99 5.3 in it. Can my 5.3 have the Castech heads? These are the heads that can crack listed in the tsb. I have 187K on the motor, all original. Thanks for the help.
Before you condemn the heads, I would look at the intake manifold gaskets. Pressure test the system and see if coolant is leaking out the rear of the manifold or possibly the manifold itself is cracked. Much cheaper fix than heads.
If you must take the engine apart, try looking at the intake when dis-assembling. Check for signs of leaking at the manifold.
1999 Gmc Sierra 1500 Engine Intake Manifold - Delphi, Dorman - TheAutoPartsShop - TheAutoPartsShop
1999 Gmc Sierra 1500 Intake Manifold Gasket Set - Dorman, Fel-Pro - TheAutoPartsShop - TheAutoPartsShop
98Silverado4Ever
02-24-2011 10:00 AM
