Couple of problems w/ 99' Sierra Z71
Old 10-07-2010 | 09:46 PM
i3oosted's Avatar
Default Couple of problems w/ 99' Sierra Z71
New here, looking for a little help.
I have a 1999 Sierra ext cab 5.3l z71.
My odometer and the P R N D 3 2 cluster works sometimes and other times doesn't. I don't know what's going on any help there would be great.
Also I changed out my cabin air filter awhile back, now fan blower speeds 1 and 2 do not work but 3, 4, and 5 do. What do I need to do to fix this problem?
Thank you for your help!
Old 10-11-2010 | 11:03 PM
lucian*91's Avatar
relay pack for your blower is more then likely bad, and my 99 used to do that, seemed the the peice wiggled loose and had intermitent connection
Old 10-12-2010 | 08:12 AM
The cluster issue is fairly common. There are guys on eBay that offer a rebuild service that fixes the issue.
Old 10-12-2010 | 01:59 PM
i3oosted's Avatar
It was the relay pack, I changed it and it works fine now.
Still needing the cluster rebuilt but it's hard to find someone that can do them, they all do the 03+ stepper motor ones.
Cheapest I can get it done is $170 shipped both ways. Anyone know who rebuilds these cheaper?
Old 10-13-2010 | 11:36 PM
lucian*91's Avatar
you could always get one off ebay cheaper.. and just record the mileage on yours before removed. and the mileage on the one before inserted. or get it electroncally corrected to match your truck
Old 11-29-2010 | 12:47 PM
clcnew's Avatar
Default Odometer Fix/DIY
Hello, I can save you the money it will take to fix the odometer problem, I created a website for this quite a while ago and it will definately work, long as you got a bit of know how. It's www.mrfixit.webnode.com Good luck, let us know how you make out
azwizard
03-19-2011 08:31 AM
Erik G
10-15-2009 12:23 PM
2001ChevyZ71
04-27-2009 02:48 PM
bpsilverado03
05-05-2008 07:03 PM
LightningStrong
11
09-24-2007 11:08 AM
Quick Reply: Couple of problems w/ 99' Sierra Z71
