Creaking steering noise
Old 06-24-2012 | 07:04 PM
SweeperForce's Avatar
Default Creaking steering noise
Hello,
I have a creaking sound coming from inside the cab while turning at slow speeds. It has no performance issues just annoying. I think the steering column is rubbing on the housing of a bearing needs lubed. Any input would be great.
Thanks,
Tom
Old 06-24-2012 | 08:22 PM
NullHead's Avatar
It could still be squeaking from outside the truck. Check your steering linkages, grease the frond end and see what happens.
Old 06-25-2012 | 01:10 PM
glterpening's Avatar
There is a known problem that has your symptoms. I have the same thing on my 2003, but have not done anything about it.
Here is the GM service bulletin: tsb# 00-02-35-003n
There is lots of info about it on the 'net.
Gerald
Old 07-05-2012 | 09:47 PM
01liftedsilverado's Avatar
its the intermediate steering shaft,its the knuckle between the box an firewall just did mine on my 01 silverado its lifted 6 inches an on 35's knuckle basicly blew out of it after a week of being lifted but o well it had too be done hope this works
Old 07-07-2012 | 05:29 PM
Thanks for all the replies, as soon as the temp drops under 100°F I'll take a closer look and fix the problem.
Tom
bikernut
10-13-2009 04:32 PM
AHVB
09-11-2008 10:57 AM
Chevycowboy
03-24-2008 10:55 AM
BawFaw
12-02-2007 08:52 PM
Giz03Z71
9
12-09-2006 03:52 PM
