crossmember on 2500HD cracks on rear sides
Old 05-17-2009 | 02:05 PM
bigchevy's Avatar
Member
Default crossmember on 2500HD cracks on rear sides
I have a 2002 2500HD 4x4 and on the crossmember that the torsion bars are held in at there are cracks that run directly through the mounting bolts on the back side of the crossmember on both driver and passenger sides. is this common? should i just remove and weld the cracks or just find an upgraded crossmember from an off road warehouse? the truck has a 8" lift with 35" tires.
Old 05-18-2009 | 10:45 AM
chrisbmo2000's Avatar
I would find a HD cross member..or weld a piece of metal over the cracks to help reinforce it
Old 06-04-2009 | 12:25 PM
bigchevy's Avatar
Member
thanks, i ended up taking it completely off. once i got the torsion bars taken out, the crossmember shook like a baby rattle. the end tabs on the rear just fell off. so i welded everything back together and covered it to prevent rust and put it all back together and is still holding strong.
Old 06-04-2009 | 07:33 PM
RUFFNECK4LYFE's Avatar
Yeah those welds should hold good.
2KSilverado1500
9
01-28-2021 08:27 PM
scott_z71
14
10-10-2019 08:26 PM
Pleszmc
12-12-2012 12:27 AM
firefighter148
08-05-2010 01:44 PM
nathan89
09-22-2008 08:48 AM
