daytime running lights
I have a 2002 Silverado LT extended cab and one of the daytime running lights is blown.I changed the bulb and it still wont come on.I see at least 4 or 5 trucks a day with one light does anyone know if GM has a recall on the lights or anything?
RE: daytime running lights
did you check the bulb? I have, on rare occasion, purchased bulbs that were bad. Did you touch the bulb during installation? The oils on your skin can cause the glass to crack when the bulb is turned on (halogens only).
Check the wires and the contacts in the socket, the contacts in mine had some crud in them preventing a good connection. If the socket is bad they aren't expensive to replace ( i don't think ).
