differential fluid
differential fluid
Hey Fellas I bought a used 2003 Silverado back in February so far it runs good it just has a few little things to fix. My question is the diffs. Can I run I run Mobil 1 gear fluid or should I get Chev's synthetic??
RE: differential fluid
ok,the poop..it is illegal for a carmaker to say "use gm fluid..or exxon oil,etc"/..all they can do is set standards and say to ,meet it..
the rear end oil in a 99 and up is gl5 synthetic...as long as it meets that,its ok.
transfer case...they change those a lot...read your owners manual for specifics...there are probably 5 different cases for the 2008 model year...saome take atf...some synthetic.
so yes,i'd buy gm...not because its better...but because i'd know i was putting the correct stuff in
Find the model number for your transfer case and either look it up online or buy a service book. (Argon might be able to find it too). But there are around 3-4 different transfer cases I believe. Some require that "special stuff", others do not. My 99 takes plain old red stuff.
lwcrow
23
12-01-2010 05:46 PM
SS327silverado
05-03-2004 11:46 PM
