Door panel removal
Door panel removal
I HAVE A 2002 1500. I NEED TO REPLACE THE DRIVER DOOR SPEAKER, BUT FOR THE LIFE OF ME I CAN'T SEE HOW TO REMOVE THE SPEAKER GRILLE OR THE DOOR PANEL. i TRIED PRYING WITH A SCREWDRIVER, BUT NOTHING SEEMS TO BUDGE. WHAT AM I DOING WRONG ????????
It's been a while for me since I had an inner panel off a 2002 but I think that what you need to do is remove the traingular piece that is at the upper end of the door where your side mirror is bolted on. Then use a small flat blade screw driver and pry out you door lock lever. The one that slides side to side telling you if the door is locked or not. Behind that lever is a small 7mm bolt. unbolt that bolt. Then I believe there are two right under the handle for pulling the door closed. Now you lift up on the handle of the inner panel and the panel should slide up and off. Disconnect your electrical connectors if it has power windows and lock and remove the speaker and replace. I think that should cover it.
rdowner22
12
08-04-2009 07:53 PM
