Drivers Side Sagging
Old 08-27-2008 | 11:58 AM
esmiff's Avatar
Default Drivers Side Sagging
I own a 06 GMC Sierra Z71 and installed a RCD 6inch lift. The rear I used the blocks along with my stock leaf springs. I have noticed over the last few months that my drivers side rear is sagging about 1.25 inches lower than the rest of the truck ( I measured the gap between the tire and fender well on the entire truck). I have doubled checked everything and can't figure it out. I haven't even taken my truck offroad yet, and I can't get a straight answer out of anyone. Maybe the rear leaf's need to be replaced?
Old 07-06-2010 | 02:26 PM
Matt D Cat's Avatar
I've got the same problem, rear on driver's side is a bit low. You can just notice it when you look at the truck from behind, but it's not more than probably an inch or two of a drop. Did you ever figure out what caused it? I was thinking that maybe i needed new leaf springs, and if I were going to get new ones, I'd get the heavy duty aftermarket jobs for extra towing capacity. '97, 5.7L 4x4 with 180K miles. Any Thoughts?
Old 07-06-2010 | 03:18 PM
timber74wolf's Avatar
Sounds like it could be a weak leaf spring possibly.
Old 07-10-2010 | 08:17 PM
Matt D Cat's Avatar
That's what I was thinking too, probably a weak spring... wouldn't be a shock would it?
Do you know of any good places to get aftermarket springs? I'll start digging around myself, but curious to see if you know of anything.
Anyhow, thanks for the thoughts.
Old 08-16-2010 | 04:18 AM
blueboy02's Avatar
my 2000 has the same problem and i think the reason is caused the placement of the gas tank puts more weight on that side causing it to sag but over time it probably wears that spring down
Old 09-02-2010 | 11:08 PM
Frank B's Avatar
Springs wear out. May even have one broken leaf. It is not easy to match them up with new ones. I had the same problem with a 99. After three months waiting on the dealer I bought the first leaf below the main. It brought it back very close. Later! Frank
redchevy
05-30-2010 07:39 AM
chevy112488
04-26-2010 06:47 PM
fishfreek
12-13-2007 03:43 PM
SouthBayZ71
07-27-2007 08:21 AM
jonesdg
01-06-2007 08:23 PM
Quick Reply: Drivers Side Sagging
