Drivetrain noise
Drivetrain noise
Hello, I am new to forum and am looking foward to learning alot. I previously owned Silverados and own now a 99 Sierra SLE 4x4 Ext. Cab 5.3l with 130,000. 4 in Fabtech lift. anyways, along with the usual "burp" or "thump" when taking off or stopping I have a fairly loud growling noise that seems to be around the rear end. Changed the fluid and noticed only minor shavings. U joints look beat so those will be next. Maybe a pinion bearing? The noise increases with accel and decreases with slowing down but cuts off if I coast in neutral. I am a decent backyard mechanic but have yet to tackle a rear end. Other than the noise it drives fine. Could this be coming down the line from the transfer case?? Any advice would be greatly appreciated. My pre 99 C/Ks never had this happen.
RE: Drivetrain noise
Do you know if you are running stock gears? If they were changed out, could be that they werent shimmed correctly when installed. I get a sound from my rear-end, very subtle high pitched whine when throttle is applied, because it was amateur night at 4 Wheel Parts when they put the gears in.
well, the gears are stock but after finding too many problems in that rear end I bought a whole rear end rotors, calipers everything off of a 04 Silverado that had front end damage for a damn good price. I'll swap it out this weekend.
Grumpy1
01-06-2010 05:04 AM
makoltd
11-02-2006 04:31 AM
