dyno
dyno
So I plan on gettin my truck dynoed this weekend and geting a custom Predator tune.About how much horsepower and torque do you guys think ill get to the crank and to the wheels just want 2 get an idea.05 Sierra 285 hp,Airaid intake,poweraid spacer,granatelli maf,flowmaster dual exhaust,edebrock headers,predator programmer.thanx
RE: dyno
A stock 5.3 Silverado got 17hp at the wheels with a 91+ tune from a Hypertech. Predator will be in that ballpark depending on how its set up. A dyno tune will squeeze out a little more. I'd say 40 more hp to the rear wheels. Maybe 45 ft/lbs. 285hp will be about 245 to the wheels + 40hp so 285ish to the wheels.
RE: dyno
Do the '05s have aluminum or iron blocks? I wouldn't force induction on an aluminum block. Nitros is a pain, the bottle is never full when you want it an if it's not set right you'll create a shortcut to the oil pan from the heads via a hole in your piston.
RE: dyno
[/align]
[blockquote]
There are alot of myths about nitrous. If u run it correctly...window switch, wideband,....etc. they can last a LONG time, 4.8's and 5.3's LOVE the bottle...they respond better and long gevity to the bottle better than boost. Most people dont know wtf they are talkin about....they just know the bad results and there are some but if u go the "Safer" routs, u will be better off.
[/align] [/blockquote]
RE: dyno
I agree that under the proper conditions nitrous can be run safely. It is my understanding that the window of proper conditions is rather narrow. In my opinion the cost of a repair due to nitrous damage outwieghs the gain in power.
