Electrical problem??????
Old 07-01-2010 | 04:04 AM
chrisbmo2000's Avatar
Originally Posted by Mr_Shamrock
Have you tried running both fans by themselves?
Yep.....EVERY time I turn both of them on this happens.....so its Isolated to the blower circut.....Slim I will have to try that..(gotta buy a clip on amp meter first)...I will probably pull the Alt and battery again.......( take Battery to Wally World for free replacement and alternator to O Riellys and see if I can get them to warrenty it out also.........Thanks ALL I will keep you updated
  #12
Old 07-01-2010 | 05:59 PM
seejgo2's Avatar
Member
Chris have you tried to run the fans with the key on but engine not running just to see what kind of draw you get directly from the battery.
  #13
Old 07-20-2010 | 11:29 PM
Yeah I have tried a lot of diffrent things....I changed the battery today and still have the same issue...I guess the alternator is going to have to have a second look.
  #14
Old 07-21-2010 | 02:24 AM
RUFFNECK4LYFE's Avatar
Hey I added an extra ground cable and also an extra positive cable from the top post battery straight to the back of the alternator, and this helped alot when my fans came on. The voltage came right back up to 14.2 after the draw with everything on. Before it was minus .4- .6 volts.
  #15
Old 07-22-2010 | 05:47 PM
I will look into doing that roughneck....I had originally thought about putting in a second battery.......which brings in a whole other question.
sickshoesbrah
03-09-2007 07:26 PM
chevyguy#1
02-25-2007 05:45 PM
Mcfish
11-30-2006 01:46 AM
quadracer
02-16-2006 09:41 PM
chrisselfz71
11-15-2005 10:36 PM
