eliminateing low fuel light in message center
Old 12-17-2010 | 09:26 PM
DONBAR's Avatar
Question eliminateing low fuel light in message center
Hi all, my fuel sending unit is no good on my 2002 silverado 2500 HD. The fuel pump works fine and I'm good using the odometer to fuel up but the message center reads low fuel. The fuel gauge reads empty. Is there a way to disconnect the sending unit?? Will it work to unplug it off the top of the fuel pump? Or cut a wire or two? Will the pump still work? No other messages come through while the low fuel light is on in the message center. Thanks for any suggestions.
Don
Old 12-17-2010 | 09:30 PM
jimmie.cutler's Avatar
replace the fuel pump module assembly. Are all your other gauges working correctly?
Old 12-17-2010 | 11:18 PM
DONBAR's Avatar
yes all gauges working. I am sure it is the module assembly. It was broken when I installed the pump. I had to install the pump anyway because I am in a rural area. The broken part was the plastic part that the float arm snaps into. I did my best to strap it on with zip ties but it did not hold for very long.
nutznky
10-24-2016 06:58 PM
QCZ71
01-19-2011 08:47 PM
Wes H
8
10-08-2010 10:04 PM
restridge
07-15-2010 08:23 PM
02AmeliaChevy
05-12-2009 05:26 PM
