Engine Code Reader Won't Connect - '04 Silverado
I have an '04 Silverado 1500, V8 5.3L (not flex fuel). My check-engine light is on.
Took to Advance Auto to have the code read. Their scan tool could not link to my truck's computer. They said to check fuses. I did and found a blown Cig. lighter fuse. I also Googled the symptom and located many posts that point to the Cig. fuse as the cause.
However, code reader still doesn't work after I replaced the 20A cig. lighter fuse.
What's my next troubleshooting step?
Thanks in advance,
-M
Thanks in advance,
-M
My fuse for the cig lighter socket was located under the hood fuse box and replacing it as needed was the problem for my truck. My 2002 model Silverado has three locations for fuses, one under the dash, one on the driver side end of dash and the one under the hood next to the battery.
My truck also has two other aux sockets next to the cig lighter that are on a separate fuse under the hood if I am not mistaken. I had blown my cig lighter fuse using a portable tire inflator.
