engine swap wiring
RE: engine swap wiring
It is possible that the senser has gone bad, how long has it been since it worked? More than likely there is a break in the wire, try to trace it down from the tranny as far as you can to the speedo. If you cant find any breaks check your ground wires, look for any that might not have been put back on after the motor swap.
chrisbmo2000
02-03-2009 02:26 PM
squirrelslayer
08-23-2008 03:46 PM
imthegirlnextdoor
01-22-2008 12:24 AM
