Engine wont Start ??STARTER??
Old 07-02-2007 | 09:48 AM
paradice01's Avatar
Default Engine wont Start ??STARTER??
Hey guys, Im having trouble with my 1999 Chevy Tahoe. Its got a 5.7L Vortec engine in it. So basically, the trucks been sitting for about a year and a half. Been workin on it a bit recently, getting ready to start it yesterday.
It wont start, when you turn the key to crank, you hear a click as if a faulty starter or solenoid. So we took the starter out of the truck, hooked it up to a battery, bypassing the solenoid, and it works perfectly fine. No weird noices or stickly solenoid.
We go & put it back in the truck, same issue again. So we tried to bypass it while it was on the truck, and it will struggle to turn the engine over as if the battery was dead, it would only turn the eninge like for 1 second, and then pop one of my ignition fuses.
Anybody got any clue whats the matter with my truck? Is the starter bad? Or do you think its a wiring issue, mind you since its been sitting, nothing has been touched on the truck, and as for voltage, its a brand new battery we put in it last week.
Old 07-02-2007 | 05:24 PM
sootjunkie65's Avatar
Default RE: Engine wont Start ??STARTER??
the starter could be toast if it spins good by itself but wont work under a load.
Old 07-02-2007 | 06:36 PM
stopspazinout's Avatar
yea sounds like a faulty starter and a low battery. but check your ground and battery cables. a loose connection can be enough to keep it from starting.
Old 07-02-2007 | 06:55 PM
Argon's Avatar
Loose connection..corroded connection...or positive cable arcing on something
Old 07-03-2007 | 09:11 AM
smoke20's Avatar
Poor engine to frame ground. Probably ahd a bad spot that corroded through.
Scott1954
10-24-2013 02:03 PM
allineman
05-07-2009 08:11 PM
Thraxxx
12-14-2007 11:38 AM
SPRCHRGDGM
02-25-2007 10:55 AM
