Exhaust Change?
Old 11-30-2007 | 10:14 AM
white_noyez's Avatar
Default RE: Exhaust Change?
Hey all, i aslo have a question, ive go a 04 chevy 1500 that im doin headers and exhaust, but i do not want the x pipe because i dont want to quiet the system but there is still the option of an H pipe. Do i have to joint them at all?? can i just go true duels seporatly all the way to the back. will that not run right or what will be the cause/effects?
  #12
Old 11-30-2007 | 10:15 AM
jcbst12's Avatar
Smoke will no the answer to that, he has duals on his rig.
  #13
Old 11-30-2007 | 01:12 PM
Cracker's Avatar
The purpose of an H or X is to balance the backpressure on both sides of the motor. True duals can result in an eratic torque curve. For peak performance you will need an H or X (X works better). There may be other issues that arise because of the electronic components of the vehicle.
  #14
Old 11-30-2007 | 07:16 PM
07_Bowtie's Avatar
I have true duals on my 07 and have no issues with electronic components
  #15
Old 12-03-2007 | 07:08 PM
smoke20's Avatar
white_noyez - The x-pipe should not quiet your system. I have one and mine sounds good. I do not recommend true duals though. These engines need more backpressure than that. The H-pipe will not remove as much backpressure as the X-pipe though. If you really want true duals, then do the h-pipe. If you don't join them, it sounds funny, like 2 4-bangers having a war. You will be much better off with a single in dual out setup. I have had to add reducers to the end of my pipes to get lowend back, and I have already gained .4 sec due to the reducers, so who knows if I had done single in dual out.
  #16
Old 12-03-2007 | 11:14 PM
rjdoolay's Avatar
Hey Smoke how do u like your trans-dapt TBS? I was looking to get one of those or a Airaid one.
  #17
Old 12-04-2007 | 08:01 PM
smoke20's Avatar
I was really impressed. I have the smooth bore, and it has been one of the best gais for cost. The only mod better for cost so far was the reprogram. I would recommend it. Faster throttle response, slight milage increase, 0-60 better.
I was a disbeliever before.
  #18
Old 12-04-2007 | 11:42 PM
rjdoolay's Avatar
I had one on my older truck and i loved having it and now i want to get a new one. the one on my other truck had the twists in it. So would recamend(sp?) the smooth bore or one with a twist on the bore?
  #19
Old 12-05-2007 | 06:56 PM
smoke20's Avatar
From everyone I have talked to, the one with twists is supposed to be slightly better. I am not sure personally. If I was to buy a new one today, I would get the twist one. But it does make a whistling noise, which may be annoying.
  #20
Old 12-05-2007 | 06:58 PM
rjdoolay's Avatar
Awesome, Thanks a bunch. I think i will get the one with the twist and deal with the whistle.
Quick Reply: Exhaust Change?
