Exhaust Manifold bolt access
Hi, I have a 90 GMC dually with the 5.7, and I am in the process of replacing the driver's side exhaust manifold. The forward two bolts are actually studs with an accessory bracket mounted between nuts on the studs. I can not figure out how to remove the bracket to access the last two nuts. The bracket supports the alternator and, I think, the power steering fluid resevoir. The nut that I can not get to is in the lower portion and appears to be attached to the resevoir. Does anyone have a suggestion before I sawz-all it?
Thanks
Thanks
RE: Exhaust Manifold bolt access
Hi, i also have a 90 sierra with a 5.7 and EVERYTHING needs to be replaced in terms of exhaust. Is it possible to have a nice sounding exhaust without spending tons of money? Also, if that's not realistic, any suggestions on what I should go with?
any and all responses welcome
thanks
thanks
perron_ts:
What i did to my truck is remove all pipebefore the catalytic converter offand take a 4 foot straight pipe into a cherrybomb and off the other side another piece of 4ft straight out the end with a 90 degree pipe, it sounds very good at idle and pretty mean when u hit it. its very cheap, as long as you have a welder and a few clamps your good to go and it only takes about an hour tops. after you have your straight pipe welded together
chucksrt
12-22-2010 02:09 PM
truckaccessorizersplus
09-25-2009 09:54 AM
07-08-2009 07:35 PM
scredlex
Vehicles for Sale
08-28-2006 06:38 PM
