F/driver side hub/brake need help
Old 12-14-2008 | 12:49 PM
vinces2600's Avatar
Default F/driver side hub/brake need help
I was drving down street heard back grinding noise, i pulled over rim was hot i took wheel off the nut that holds hub to half shaft or front drive train shaft on was loose i tightned it back up every thing tight no sight anything else wrong, when i heard grinding noise i lost all break preasure after tighhting nut was fine got brakes back so i thought,, any way i drove it felt fine i stopped tire smoking again break preasure gone this time break pads appear to be fine not new but still have meat on them i notice where metal was grinding metal rotor was touching in back a plate ,, what would cause this to keep rubbing i dint hit anything just driving along this happens is a 4x4, any help would be great need to fix this beast b4 snows lol
Old 12-14-2008 | 12:53 PM
vinces2600's Avatar
Default RE: F/driver side hub/brake need help
problem with front pass blinker i check all blinkers replaced all bulbs back one work great front one still doesnt work any ideas,, also with healer blower i think i turn on car start hearing a ticking noise under dash load kinda,, for like 15 sec is blower to heater i think after 10 - 15 sec it stop unless i turn car off it will do it again i have no heat at all
Old 12-14-2008 | 01:36 PM
Chevyalltheway's Avatar
Sorry if I offend you, but I don't think anyone can answer your question if they have no idea what you are saying. I read both of those twice and neither one makes any sense. USE PERIODS!! They help, I promise. I know that a lot of guys on this forum will completely ignore that post because it is indecipherable.
What I am trying to say is: USE ENGLISH THE RIGHT WAY!!!!!!!
Kyfabrication Kyfabrication
04-15-2015 10:32 AM
jte52003
02-06-2012 07:42 PM
boxerharley
11-27-2010 12:32 PM
tamarac
04-09-2008 01:01 PM
