fan
Old 07-23-2011 | 06:26 PM
bharmon444's Avatar
Default fan
Want to convert from clutch fan to an electric and have couple of question that maybe someone could answer.
How do you wire it into the truck so that it comes on when it reaches the temperate?
Is there any special things you have to do other then remove the fan and clutch assemble?
Puss or pull ?
If anybody can help i would really appropriate it .
Old 07-23-2011 | 07:40 PM
What truck are you wanting to do this to?
Old 07-23-2011 | 07:53 PM
I've never done this yet... but I hope to some day soon. So hopefully somebody will be chiming in that HAS done it.
I expect you'll have to install a electronic temperature sending unit. It will provide the 12VDC to your cooling fan when the unit reaches peak temp, it will complete the circuit
Old 07-24-2011 | 05:31 AM
Razoo's Avatar
New electric fans come with temp sensors. Some will work of your coolant temp gauge sending unit.
I've even seen an old one from back in the day that actually had what looked like a hose clamp to go on the rad hose. It actually punctured a hole in the hose!
I've seen another that use a replacement radiator cap that had a sensor built into it.
Less costly one work with a simple toggle switch.
My recommendation: Go to a parts store or speed shop, and talk to someone there about the different type of sensors available today. Or do some on-line research.
My son installed electric fans in his truck, and it was essentially a plug and play set up. It had a tap that went on to the engine temp sensor.
Old 07-24-2011 | 09:02 AM
If the truck is new enough black bear performance sells a harness that turns the fan(s) on via the ECM.
Prescott
09-03-2007 03:15 PM
Prescott
01-21-2007 11:47 PM
black4x4
9
01-11-2007 01:40 AM
jman1
10-28-2006 10:10 PM
FX4 Matt
06-08-2006 05:55 PM
Quick Reply: fan
