Flex-a Lite Fan Installation - HELP!
Old 04-25-2007 | 10:25 PM
powwwow's Avatar
Default Flex-a Lite Fan Installation - HELP!
1999 Silverado LT w/ 4.8
Monster Fan #292
This is turning out harder than I thought it would be.
Question: Where is the best ignition positive signal for junction #9? Just need a HOT when key is ON from somewhere in engine compartment. Does not seem possible to take signal from any fuse inside the fuse box as suggested.
Question: How do you determine if theA/C clutch is activated by a positive or negative signal?
Thanks for any suggestions,
Stephen
Old 04-25-2007 | 10:43 PM
smoke20's Avatar
Default RE: Flex-a Lite Fan Installation - HELP!
maybe there is a "courtesy" fuse, power brake, power steering, or windshield wiper fuse you can tap into.
Old 04-26-2007 | 07:36 AM
Argon's Avatar
Surely there is a slot in the underhood box you can use...if not,run a wire inside to the convenience center....its down by the brake pedal..(No fuses in it,just some plugs and empty holes to use for this purpose)
The a/c...it is asking this...the truck either has a continuos ground and the relay turns on power......ORit has continuous power and the relay turns on a ground for a/c..
Do you have a test lite to check it?..IT SHOULD BE "GROUND-ACTIVATED" but making sure with a test lite is always best
nicholsr44
08-19-2010 10:20 PM
white06
13
02-04-2008 03:54 PM
BigTexasChevy
04-27-2007 03:17 PM
rodesmg
02-23-2007 01:44 PM
djsoupstyle
01-03-2007 04:17 AM
Quick Reply: Flex-a Lite Fan Installation - HELP!
