Four Wheel Drive Will Not Work
Old 07-17-2011 | 04:43 PM
Man In Black's Avatar
Default Four Wheel Drive Will Not Work
I just bought a 93 GMC Sierra 5.7 with 5 speed standard trans and was told that the four wheel drive works but only the light did not work. Turns out nothing works. Is there a fuse for it that I can try first or which switch would you suspect? There appears to be two, one on the front axle and one on the transfer case. The transfer case shift lever works through the positions easily.
Old 07-17-2011 | 06:30 PM
Wiked's Avatar
do the switch..
i bought mine like 2 days ago with the service 4WD light on. I swapped the switch from my old truck to the new one and it works perfectly now
Old 07-17-2011 | 07:32 PM
Originally Posted by Wiked
do the switch..
Which switch? There are two and I don't know what each one controls and the 4 wheel drive light doesn't work either.
Old 07-17-2011 | 08:17 PM
Wiked's Avatar
i think they are both connected
and the light not being on could be caused by a bad switch
the one in my truck the light wasnt on either and it was 1 single unit. (i have a 99 silverado)
chuc819
12-28-2019 04:56 AM
darkfire5000
01-28-2009 12:28 AM
darkfire5000
12-22-2008 12:24 PM
peli
07-23-2007 03:13 PM
unversed
07-21-2007 12:24 PM
Quick Reply: Four Wheel Drive Will Not Work
