Frame Beaming
Old 06-24-2011 | 05:41 PM
EasyMoney32's Avatar
Post Frame Beaming
I recently came across some topics about frame beaming and from what I've read, it describes the exact symptoms for the issue I've had with my truck since purchased brand new almost 5yrs ago (2007 Silverado 1500 LS crew cab 46K miles). I've taken it back to dealer about 4 times and I stopped trying to get this fixed after fourth time as it's always an inconvenience having to give up transportation for a day or two and instead I tried getting used to the vibration but it's very annoying and embarrasing at times when I have collegues riding with me. So far the chevy dealer has offered no real fix or nothing that even rhymes with "frame beaming" has ever been mentioned to me by the service reps/techs. Just a simple tire rotation, balancing, alingment, etc... is all they've done. Now I'm trying to find out as much as I can regarding this issue or anyone that may have some useful feedback, a solution or fix for this issue. Thanks!
Old 06-24-2011 | 10:30 PM
altyson60's Avatar
what is frame beaming?
Old 06-25-2011 | 03:20 AM
Wiked's Avatar
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Beam shake vibration is usually felt in the seat and occurring at speeds between 40-50 mph (64 - 80 km/h). Hertz readings using an EVA tool are normally between 8-24 Hz. This condition is most common on extended cab and crew cab models but has also been noted in other models.
Recommendation/Instructions:
The severity of beam shake may vary from vehicle to vehicle. To determine if the concern is beam shake, please perform the following:
Test drive vehicle to confirm the condition. A beam shake condition will usually respond to concrete type pavements more than asphalt, so the vehicle should be driven over both surfaces if possible.
Place 200-500 pounds in the pickup bed between the closed tailgate and the wheel wells. A beaming condition should dissipate.
Note: Tires with excessive Radial Force Variation (RFV) or out-of-roundness can intensify the frame beaming concern. The following radial force variation numbers should be used as a guide:
P-Metric tires (2WD 1500)
12 lbs or less
P-Metric tires (all others)
24 lbs or less
LT-tires
30 lbs or less
If the concern is determined to be beam shake, this is a characteristic of the vehicle and currently no repair attempts should be made. With your help in the use of the Field Product Reporting process GM Engineering is currently developing an enhancement to the body mounts to reduce this concern on the 1500 Models. On going testing has pushed the timing of these mounts to the first half of 2007. There will be no enhancement made to the 2500 and 3500 models. At this point no more Field Product Reports are needed and thanks for your help.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Old 06-25-2011 | 03:22 AM
Wiked's Avatar
GM has also made new mounts that can help stop this go to your dealer and they should be able to help you out
Old 06-27-2011 | 04:42 PM
Thank you wiked I'll do some more research with your input! Very much appreciated!
snowdevil
11-29-2011 07:17 AM
mikenn
06-25-2011 03:28 AM
Dangerous
05-24-2010 10:27 AM
ejw78
05-26-2006 02:57 AM
rmrider803
07-28-2005 10:09 AM
