Front end vibration problem
Old 06-23-2010 | 09:26 AM
Black07SierraZ71's Avatar
Default Front end vibration problem
I started having this problem a couple weeks ago and can not figure it out. When I leave for work after the truck has sat all day and get on the highway, I have a very noticable front end vibration. I have had the wheel balance checked and its fine. Funny thing is, after about 10 to 15 miles of driving it goes away. Then when I head home from work, same thing, vibration for the first 10 to 15 miles and then nothing. Anyone else run into this??
Old 06-23-2010 | 10:13 AM
RUFFNECK4LYFE's Avatar
Check the hub bearings. They usually go out after 80-100k miles. Do you hear a low hum?
Old 06-23-2010 | 10:20 AM
dmccartyfan's Avatar
flat spots on the tires?
Old 06-23-2010 | 11:10 AM
tasutt2009's Avatar
If not already done.... check inflation, may have one or both low pressure. after 10-15 miles heat will increase and vibration will decrease
Old 06-23-2010 | 02:04 PM
I noticed the tires on my wife's Yukon (Firestone Destination LE) are rough riding for a short while like you are describing. It's feels like once they warm up they get softer and ride better. It is worse when it is cold out.
Old 06-24-2010 | 06:48 AM
Truck has 62000 on it. No hum. Tires have 7000 on them. Got them put on in January. Just started a couple weeks ago. Tires all have 35 psi in them. Gonna have the tires checked to see if they might be aout of round or something.
BRW
06-20-2012 11:13 PM
truckasaurus
05-01-2010 09:10 PM
gmcchevylover
03-02-2009 10:03 AM
4x4hunter
07-25-2007 06:18 PM
4x4hunter
07-25-2007 12:58 PM
