front fender replacement
I need to change my front ds fender due to damage, but it looks like the door hinges mount with the same bolts in one area. Do I have to remove the door or will it stay in place if I remove the bolts to remove the fender? I just don't want the door to fall off
thanks jamie
thanks jamie
RE: front fender replacement
I meant to say I'm worried about the hinges coming off and the door with them. So the hingeshold the fender on by the two large bolts that point toward the front fender, and those bolts don't hold the hinges onto anything at the same time aswell? I can't see any other fasteners holding the fixed hinges to the cab or anything else.Are the fixed hinges welded to the cab or something?
98tanchev
04-07-2006 05:31 PM
