fuel pressure regulator
Old 06-01-2009 | 04:03 PM
bpa1216's Avatar
Default fuel pressure regulator
How hard is it to change the fuel pressure regulator on a 98 gmc sierra 5.7 L. Any help or directions would be greatly appreciated.
Old 06-01-2009 | 05:14 PM
RUFFNECK4LYFE's Avatar
Pretty easy. Look on the fuel line for the regulator. There is a clip that holds it in place. Some are pull clips and others are C clips that you have to use needle nose tools to take off. Once you take it out, it should pop out or you may have to wiggle a little. Before you do anything, relase the pressure form the system. There should be a valve stem on the fuel line. Looks like a place to put air for a tire. Stick a phillips screwdriver in there with a rag over it cuz it will shoot out for a second. After that then your home free.
Old 06-01-2009 | 05:19 PM
Old 06-01-2009 | 06:08 PM
bpa1216's Avatar
Thanks for the reply, still not certain of the exact location.
Old 06-06-2009 | 01:42 AM
vortechpower's Avatar
Mine is on the sending unit in the tank. I replaced the whole sending unit, it comes with it.
98Silverado4Ever
04-12-2011 12:58 PM
hroraback
08-18-2009 07:21 PM
Rhyse62
04-20-2009 09:08 PM
wlbruder
09-18-2007 04:22 AM
funhemi
02-12-2007 11:02 PM
Quick Reply: fuel pressure regulator
